XSPC D5 Dual Bay Reservoir Pump Combo - Fill Port Leak!
I've got the new XSPC D5 res as well, didn't use the fill cap that came with it though as fitted an external fill port. No leaks at all though.
I used the XSPC M20 to G1/4″ Fillport,
(where in Cornwall out of interest, I'm in St Austell)
Can you please post a picture of how you have it setup?
I take it you extended the fill port with some pipe and then capped it?
No prob here you are (crude photo's though as just taken)
As it is:
With plate removed:
With pipe turned:
I just wanted an easy way to fill/top up without pulling the res forward.
well the old one has never sealed properly and as i said its only 2 days old the pump and the plexi top, its been apart twice now
If its only 2 days old and leaking cant you return it?
(Haven't read the whole thread, sorry if I missed something)
^JP^ - sorry to hear about your issue.
I have emailled XSPC this morning with a link to this thread.
hopefully I can get this resolved as soon as I hear back from them.
Thanks RJK
I am happy with the res now I have fixed the port, there was a thread last night that I guess has been deleted where a guys OCUK Watercooled PC build had leaked on his way home with it and it looked like the exact problem I have avoided by fitting the larger O Ring.
Just wanted to make people aware before they tip their systems to bleed the air out!
w8 on you response, when they contact you.
this was in my basket till i read this, i like things to work straight out of box.
but reading this has put me right off, hope this is sorted out soon.
