These are the perfect upgrade for my barb.
Where did it drop?
Act 2 Inferno, 3rd wp
Where did it drop?
Now I understand why you couldn't comprehend playing through the game a second time with one class![]()
That spear is worth at least 1.5million
8 levels to try it out, forgive me. I'm an old-skool D2 player who knew all about rushes and i was curious as to how the D3 kids are doing it.
You really made no sense in those earlier posts. Sorry, and i don't want to sound like an arse, but i doubt a single person would agree with what you were saying last night. You were just fundamentally wrong.
Yes you paid 150k and gained 8 levels to try it out![]()
No, you just refuse to acknowledge that playing through the game and changing skills at 60 are not the same.
Trying to criticize me for seeing how powerleveling works in the game is completely irrelevant.
There are only a few viable builds for inferno, and well you are forced to use them as they are the better of your options.![]()
He's correct Evilsod. There is no reason to play through the game again with the same class unless you want to.
This is sadly true. And there are too many runes that are just so bad there is no reason to ever select them. They just don't inflict enough damage or cost too much to cast or have too long a recharge time or so on and so forth.
... I know... Did I say anything to suggest there was some sort of benefit to it other than the experience of playing through your character with a different skill set in mind?![]()
Probably like all, 60 barb having a mare on Inferno Act 2, below is a pic of my current stats:
600-650 basic res,
9.8dps,
9k armor
43781hp...
but champs/elites just need to look at me and I die! Just the standard defensive build, war cry, leap, revenge, ignore pain, frenzy & furious charge... what should I look to improve on to??
DOH! I had to go out - oh well, I'm sure I'll get an upgrade soon enough.No else has got back to me about it so sure!
Try swapping furious charge for threatening shout with intimidate. 20% damage reduction is a lot and the slowing effect is really useful when you need to get out of there.
What passives are you using? Generally I stick to relentless along with nerves of steel and superstition. Relentless is a very nice passive which can save your life against many affixes and you can even pair it with seismic slam for infinite knock back. Make use of this cheese as it is going to be impossible in the next patch.
If you can, try and get some life on hit, even if you just grab a weapon with a socket paired with a star amethyst it will make a big difference. I completed act 2 without any life on hit but it makes everything much easier.
Your resists and damage are much better than mine and your health pool is acceptable, so you shouldn't have too much trouble tbh.
yeah maybe that's the way forward, I'm using the same passives so I'll try swap the skills over and pick up a decent life on hit weapon (if not too expensive)... I guess I could just be getting unlucky with the elites I'm going up against skills wise!
I feel I'm only a few items off getting through act 2, need a better shield with higher block and block amount, I think that will help! I'll report back on the progress lol
