I assume you've looked for jobs in bike shops?
I rang Edinburgh bicycle coop and asked if there was any jobs, they said yes send an email, so I did in reply but heard nothing back. I'm going to go to Evans tomorrow on Deansgate and the Manchester Velodrome and ask, I would really like a job in a bike shop.
just take any unskilled job you can get, then look for something else while you work there, you can't be picking and choosing when claiming JSA, that's not what it's there for.
I'm going to apply at Asda in trafford, my only concern is its 20 hours, at minimum wage this is £121 and 60 pence per week, after tax/ni would I be able to afford to rent a place off of that?
You go in, they treat you like you're dumb,chav and what to live off £52 a week.
I had a really easy time while on JSA, I think they were intimidated by my intellect.
but believe me when i say even asda tesco etc jobs are HARD to get in this climate
Apply for Working tax credit ?
Well, yes you can. When I was on JSA I made it clear I was a digital designer. Every week I went there they said "Here's a job for a programmer in XYZ for £40,000 a year". I had to explain every single week that I do not know certain specific languages and that it'd be useless applying for them. But still, they got in a tantrum if I didn't.
Edit: Just saw you said unskilled... I'd say I'd be as bad at learning painting and decorating as I am at programming in a language I do not know.![]()
