*** The Official Diablo III Thread ***
Status
Not open for further replies.
I'm definitely due a Legendary I think....
Preferably an iL60+ one xD
kd
Not possible. Game has a sense of humour when it comes to Legendaries. You may get your wish and it will be an ilvl60+ one, but it'll be a weapon which are all practically worthless.
Or you'll start a new character and halfway through the first act 'The Barber' lvl11 dagger will drop.
Or like my Barb... I bought her a Broken Crown, then found 1 in Act III with similar stats ><
Had this drop couple days ago :)
Any offers lol
That is a beast!
Someone will likely pay well over the odds for that bad boy, not only are the stats/dps good but the Reduced level req of 18 makes that a sure thing for someone leveling a monk with loads o gold.
It's pretty much all you'll need from lvl 42 (which will make all acts ezmode) up to act 2 inferno probably.
I'll give you 10 chipped rubies and pat on the head for it...
Wow, I was thinking "Hmm.. that weapon doesn't seem to be too good"...
Then I saw the level requirement -18.
That is seriously overpowered to have at 42 lol. You'd oneshot almost everything.
Stormshield would keep me happy xD
Just realised the Level decrease on that wep, it really is impressive.
Probably a good few mill right there....
kd
I am really jealous and angry in the same time. |Peps having all that drops (even friend had 2 legendaries , one of which from Pony land on Hell ! ffs Windforce with no mF gear whatsoever ) and I on the other hand trying to get 1 decent piece of loot from whenever and no luck after spending hundreds of hours... very frustrating not mentioning when I die few times the bill go sky high...
Finished Act II Inferno on my Barb now. A couple of elites that would've been almost impossible for me to survive against (like the Molten, Fire Chains Jailer Spiderlings that hit for 5k... I went another way and skipped em) but for the most part I didn't die against most elites. The ones I did die against it was usually no more than once, twice max, and it was usually my fault for being reckless. Like the Horde Molten Serpent where Vengeance killed about 5 minions at once... and I didn't run away ><
Act III on the other hand. Definitely need a gear upgrade. Killed by the regular enemies due to being careless (they bloody hurt though) just inside the first area, then came across a Molten elite, pulled it to the stairs in the hope I could tank it with WotB and beat it to death but between the massive amount of hp it had and the fact the first minion I killed exploded and killed me from full hp... I need more hp, armour and resistance. Preferably damage too but I need better survival first.
Belial was fun. First phase I beat him down with WotB in 10 seconds, second phase I messed up dodging the meteors. Second attempt, a long fight against his first phase and did a better job killing his second phase. **** loot though.
How did you get on against Bilial (sp?)? I am stuck on him and keep making stupid mistakes or hit his enrage timer, doing my head in now :)
Easy enough. With WotB I could bring his first phase down in around 10 seconds depending on luck with criticals. Without it it was a pretty damaging fight which could've gone bad quickly if I wasn't careful.
Second phase, not much to say really. Dodged his meteors. Dodged some punches, tanked some with Leap/Ignore Pain. Tried to do as much damage as I could really. Was half a second from getting myself killed when he was on 1% hp by deciding to kill him instead of being cautious ><
If you're hitting his enrage timer you need to either change your skills to be more offensive (his drops are a joke anyway so NV doesn't matter) or equip a better weapon, even if its only for his second phase. What class are you?
I feel a bit stuck now. I'm trying Act 1 Inferno but I am dying way too much, almost every elite pack will kill me at least once, and I can't afford the repair costs now as progress is slow.. How can I progress from here? (60 Barb btw)
Either your gear is very sub-par or your skills aren't really ideal. Whats your armour/resistances/hp/dps/skills?
I like that repairing is a goldsink now but all it's gonna do is lead people to spend all their gold meaning they can't afford to use any of their items and quitting or just spending loads of money on the RMAH.
The game is still better than D2 was after 1 month but it seems to me that Blizzard make it crapper with every patch.
gear is definitely sub-par yeah. I just got to the end of hell and started on inferno, but don't have any gold yet to get better gear - do you have to farm hell for so long before you can move up?
Can you do a quick knock up of the items you have at the mo? I'll have a look through my stash and see if theres anything you can upgrade to. I know I have a few all resist things...whether they're good or not is another matter :p
It really depends how you go about upgrading.
If you're really struggling, it might be worth completely forgetting about all your gear and looking at getting an absolute basic set of equipment with all res. A quick search for Chest Armour for example, if you look for 78 all res and str you're looking at ~100k minimum. If you just want 58 all res with strength you can pick up 350-400 armour pieces for 5-10k. Maybe you'll get lucky, theres was a piece up for 12k with 750 armour.
Its just making sure you get gear with str, vit and all res fairly evenly. You won't need every single piece with all res for act I but it gives you something to build on.
Status
