Here is a few pictures of mine to get us started,
i need a little bit of inspiration,
and the thread will serve as a good resource for other owners looking for inspiration
Dont know if this thread will fall or fly, but either way, please keep posts relevant
pictures of the PC's and questions/answers relating to the pictures are fine
le girlfriend figured that a mousemat would be the most appropriate item to buy me cos my desk is where i spend most of my time
need to dust it a bit, buying some bitfenix alchemy cables, white led fans and cathodes, going to do the cable management properly, re-routing those pipes which are bent in a strange direction, putting two akasa apache black's in push pull on the rad. If i had the money i would add another hard drive (1tb or more) and maybe change a few other bits and pieces
. Is that an SSD above your HDD I can see in the last picture and if so are you running in RAID?
