Post your pictures: Lancool Dragon Lord
Caporegime
29 Jul 2011
In acme's chair.
Here is a few pictures of mine to get us started,
i need a little bit of inspiration,
and the thread will serve as a good resource for other owners looking for inspiration ;)
Dont know if this thread will fall or fly, but either way, please keep posts relevant :p pictures of the PC's and questions/answers relating to the pictures are fine :D
le girlfriend figured that a mousemat would be the most appropriate item to buy me cos my desk is where i spend most of my time :p
need to dust it a bit, buying some bitfenix alchemy cables, white led fans and cathodes, going to do the cable management properly, re-routing those pipes which are bent in a strange direction, putting two akasa apache black's in push pull on the rad. If i had the money i would add another hard drive (1tb or more) and maybe change a few other bits and pieces
Man that looks really good :) . Is that an SSD above your HDD I can see in the last picture and if so are you running in RAID?
Thanks, means a lot :)
Yeah it is an SSD, an OCZ Vertex 2 40gb. The HDD below it is a Samsung Spinpoint F3 1TB.
The OS is installed on the HDD, the SSD is running as a cache drive for the HDD.
The drives are set up as RAID in the BIOS yes, but they are technically not in 'traditional' RAID. It is an Intel Smart Response Hard Drive Cache array.
Could you have gotten that CPU connector behind the motherboard? The case doesn't look too great for cable management, other than that it looks pretty superb.
And also, what headset is that? ;)
Yeah you can if you get an extension for the CPU cable, running it around the back its just to short. Just realised I need to take some new photos of my case now I've got a new graphics card inside :)
Nahh it is too short unfortunately, but I am getting alchemy cable extensions.
The 'headset' is a pair of Koss PRO DJ100 headphones :p
I use a cheap clip on microphone, i need to buy a new clip on mic.
Photo's of my Lancool K56
Been thinking of fitting a second intake fan above the first one, and maybe one more exhaust on the top, what do you think?
More pics? Please? How is the mobo thumb mounting?
Sure thing, I can't guarantee that i will get them on here at the speed of light but ill try my best. What do you want pictures of? If you're not sure I'll just take some general internal and external pics and put them up.
The motherboard thumbscrew mounting was very nice, much easier that using normal screws, but it's a bit difficult to screw a couple of them in by hand (movement is too restricted) so I used a screwdriver for a couple.
The HDD bays if you could, how is the cable management? If its decent this case is for certain myne!
A few of my K58. I really do love this case, although often think I would prefer the black interior of the K62.
Hi jarvis82,
What is holding the second intake fan in place, looks like foam? Been thinking about adding another fan up there myself. Also does the addition of the top two fans cause a noticeable difference for you in terms of temperature? :)
Hi jarvis82,
it appears to be packing foam.
