- 3 Oct 2009
- Wales
Way to go yet i think, can't make 22 PPD
I'll get some 0% brightness action on the go and try and get 6 hours with the X, just to rain on your parade...![]()
It's okay as long as I don't go outside!![]()
yeah i've had 5 hours before but not with quite so heavy use i don't think, also slightly higher brightness for the majority this time. Quite consistent though i have to say.
I've not tried it running zero brightness for long periods of timeMaybe that's next on the cards. I need another formula 1 weekend though so i can justify using my phone all day
(*disables all syncing and as many apps as possible in preparation)
edit: ohhh yes avatar change![]()
How is the battery life on the X with that ROM and your normal usage now? Still the same?![]()
Hard to say at the moment, it's definitely quite a lot better than it was before, but I don't think 4 hours+ is going to be a regular thing.
Switching around between apps and doing various different things takes a greater toll on the battery than just watching a video, so it's what I expected really.
I think 3 and a half hours screen time over 30 hours will be what I get on average, which is perfectly fine I suppose (that's with no video watching, so it's browsing and such mostly).
I think I'll be able to get some good results with the GS3 when I get it (in a couple of weeks or so).
Sounds a lot better than stock anyway!
Is that with auto brightness or manual control?
Browsing is the biggest killer for me, I think if I didn't browse as much, 5 hours+ would be standard. Damn AMOLED screens for browsing!!!!!![]()
It will be interesting to hear your overall thoughts on the GS 3 especially battery life as it still seems to be mixed user reviews on it.
You going for white or PB?
Auto brightness (which is why it's particularly good)!
I'm going for blue. I like the white but I think in the right light (indoors) the blue model looks pretty good. I don't think the design is remotely inspiring but it looks good enough if the rest of the phone ticks all the boxes.
The small black border around the edge of the screen is far more potent on the white model too, and that will just get annoying and makes it look dodgy.
That's odd nexus i seem to get the same whether i use it mostly for browsing or video. Today for instance i was browsing on and off for the entire GP which was from like 1pm till 4/4:30. Minus the ~hour and a half video this morning the rest of the screen time was browsing which got the same usage as when i spent about 4 and a half hours watching video a while ago![]()
Completely agree with you! White phones and any devices just don't do it for me (use a white TP-link adapter and I can't stand looking at it!!! Tempted to paint it black![]()
) and I wasn't impressed with the white GS 3 at all, too glossy and shiny and as you said the black border around the edge of the screen is annoying, the silver trim on the sides looks rather good though.
I do quite like the look of the white X though, but I don't think I could live with it for 1+ year(s)
A nice rock/nillkin case will make the back of the GS 3 look better as well![]()
Also, does anyone know what "tpd" is? It uses a bit of battery, but I have no idea what it is![]()
Yeah, I'm not a big white phone fan either, but I think the X looks great in white due to the design of it.
I had a white iPhone 4, but only because I'd had two black ones previously so wanted a change before the 4S came out. After a short while I really didn't like it (even though it looks okay, the black is a lot better), the border around the screen bugged me no end!
I think I'll get a rock case and see how it goes. They do look good (though that could just be some fancy photography, wouldn't be the first time...)
Google suggests it's a Twitter widget?
Sarge - Is there any way proving that? I ask because there is something stupid going on with it's mobile reception.
Really?!
Browsing is the main thing that absolutely hammers my battery compared to everything else, it is the biggest drainer by far, will post a better battery stats screenshot sometime (I can get good battery use out of it though, about 1 hour activity and still manage 4 hours+ on screen time)
Here's a v.quick screen shot of the type of thing that's going on. (accelerated with death grip for the chart, actually death grip is probably the biggest issue with this phone tbh)
