*** The Official Nokia Lumia 710 Thread ***
Right so we'll be waiting an age then I guess. I thought that it wouldn't matter what network you were on. Oh well. :(
:p
Done with Navifirm/Nokia Care Suite. Really nothing exciting unless you want to share internet over WiFi.
Does it automatically detect that there's an update or do you have to download the update first? Also will it basically do a factory reset when you do it through the Nokia Care Suite?
Downloading from ZUNE now :cool: i had to use the mango force update method, by turning the phone into airplane mode, check in zune for an update if it says its upto date click ok, the press one above or below the update option, next click update and around 2-3seconds disconect from your internet conection, hopefully it will say update availible, reconect click ok, and sit back :D
Tried this, but it seemed to just redownload 8112 for me. Derp?
EDIT: Tried it again and it seems to have found it.
