I need a bit of "how to get ladiez" advice
I'm patiently waiting for tips here, eating a snack.
You had her at McDonalds tbh. OP prepare to be proposed to, you and your expensive taste.
One thing I forgot to mention. I didnt pay for her McDonalds. This makes me look good and shows my authority as a man...right?
(was hanging out from the previous night and didnt really think, in retrospect - this was a purrrrty bad idea...)
When you're in a situation whereby you're able to have what you're describing it's so insanely easy to get that it's basically inevitable, unless you really go out of your way to stop it.
What I'm saying is, you don't need any tips.
And again please? Didnt really get it...You RAF lot are too intellectual for me... ;)
If you're ever in a situation where it's possible for you to get what you're describing (as in, she wants it too) then you don't need any tips or tricks, it'll almost certainly happen. You coming on a little too strong or not won't make a blind bit of difference if she does want more than just you having a go on her jublies, and if she doesn't then it's not going to happen anyway!
Yea I spose you are right - but still wouldnt mind coming across as not mega desperate, and would like to come across smoooooooth... :cool:
Take her to Greggs and buy a pasty. Throw it on the ground in front of her then make eye contact while pointing at it and slowly nodding... she'll be yours in no time.
Or if you want to be ultra dominant:
Go to Greggs and you take a massive bite out of a pasty; throw it at the wall and then pound it and pound it again with your fists then lick the bits of onion and meat stuck between your knuckles. She'll know what it means.
