Seen a few posts recently from Demon Hunters who are struggling with Inferno, so thought I'd post a sort of guide to the way I approached the game which should hopefully give some options for people to explore.
I've played a DH since day 1 of release. I cleared all of Inferno (including Act 1) pre damage nerf, but post smokescreen duration nerf. I did this using the glass cannon approach, which is to stack dex, crit chance, crit damage and attack speed at the expense of all survival stats. Before patch 1.0.3 this was a very viable build due to the damage provided by Nether Tentacles and whilst I died a lot since basically 1 hit from anything would kill me, I still progressed steadily and was able to farm Act3 and 4 pretty effectively.
Since patch 1.0.3 I found this playstyle a lot less viable. Damage from Nether Tentacles was halved, and the reduction in attack speed on items meant longer fights, meaning more opportunities to be one shot. Whilst there are still glass cannons out there, it requires high levels of concentration and a lot of patience due to deaths from 1 shotting.
Just before 1.0.3 hit, I sold all my gear on the RMAH and then when 1.0.3 hit I started at the beginning of Act 1 with a character naked except for a chest piece and a 900 dps bow I had in my stash.
I decided to regear as what I think is probably Blizzard's vision of how a late Inferno DH should be geared. This means, getting enough survival stats to be able to take a few hits whilst still keeping dps high enough to make farming viable.
Firstly we need to think about how much of everything we need to survive. Then we need to look at what each gear slot has to offer in terms of possible properties to decide where we need to make compromises to keep things on budget.
The key stats we are interested in are
Dexterity - Damage and dodge %
Vitality - Health
All resistance - Reduced damage from all types
Physical resistance - Reduced damage from physical attacks
Armor - Reduced damage from all types
Critical Hit Chance - Increases the chance to crit
Critical Hit Damage - Increases the damage from each crit
Attack Speed - Increases rate of attack but also speeds up the attack animation , important for 2h xbow users who kite!
Secondary stats which we dont need to stack, but do provide benefits
Intelligence - 10int = 1 all resist
Strength - 1 str = 1 armor
Life % - only of real value if you have lots of Vitality
Fire resistance - Reduced damage from fire based attacks
Life on Hit - Adds x amount of life per successful attack
So, how the heck do we go about balancing all of this? Well you can use a tool like
http://rubensayshi.github.com/d3-ehp-calculator/ which gives you an effective health value for each stat. This if nothing else will highlight the importance of resists in increasing your effective health.
Its very difficult to put a 'you need THIS much to survive Act x' because so much depends on your playstyle and, to be honest, your skill level. What I'm going to do is give a slot by slot guide as to what you should be looking for and leave the exact balancing of each slot to you. For Act 1, dont look for perfect items, just try and be balanced and then upgrade incrementally as you find stuff or make enough gold to buy on the AH. Always be mindful of any tradeoffs you have to make and have a plan to make them good in another slot so you are never going backwards. For instance if I trade off 30 vit on gloves for a dps upgrade, I'll be looking to gain 30 vit somewhere else.
Primary Weapon
Look for the highest dps weapon you can afford with either a socket or high crit damage and ideally a high amount of dexterity. Vitality and life on hit are a bonus.
Amulets and Gloves
These are your big dps slots. They can have the highest values for Crit Chance and Crit damage, and can also have attack speed. You should be looking for high dex + at least one of the 3 properties already mentioned. The more the better but the price rises exponentially as each is added to the same item. You should also try if possible to get some resistances (ideally all resistance) in these slots but for Act 1 it wont matter if you dont. If you can only have 1 resist, make sure its physical or fire. Vitality is a bonus.
Rings
These are your secondary dps slots. Rings can have crit damage, crit chance and attack speed but at lower maximum values than amulets and gloves. To start gearing I would be looking for dex + crit chance + a little bit of vit and resistance. Again adding multiple damage adding properties sends the price through the roof.
Helm
You can gain a big chunk of life % by getting a helm with a socket, but to start with look for Dex, resistances and crit chance 3% or higher. Vitality is a bonus.
Bracers
Same as helm but no chance of a socket.
Quiver
Quivers were the only item that didnt get an attack speed nerf. They can also have the +max discipline property which adds massively to your survival due to allowing increased use of DH defensive skills. Finally a quiver can have pretty high critical hit chance. A decent quiver will have all of these and some dexterity. So, Dex, Attack speed, Crit Chance, Max Discipline.
Boots
The one unique property for boots is movement speed. 10% is enough for you to be able to kite most things that dont have a fast affix. After this you should be stacking dex, all resistance and then as much vit as you can get whilst not compromising on the first 2.
Legs/Shoulders/Belt/Chest
These are your big survival slots. They cannot roll any useful dps stats other than dexterity so you should be using these to stack as much vit and resistance as you can whilst still keeping dexterity high. Life % is a bonus, as is +max discipline on chests.
With these gear weightings in mind, you should be able to plan a series of upgrades that fits within your budget but also makes your character both more powerful and better able to survive.
Build
the build I use is as follows
Hungering Arrow + Devouring Arrow = Best single target dps a DH can get with decent crit chance
Elemental Arrow + Nether Tentacles = Even post nerf I find this the most comfortable hatred spender. When gloom tanking the bit of lifesteal does help. The fact it passes through targets helps with invun minion champs. Slow moving means you can walk them into mobs that are just off screen.
Vault + Tumble = I find this invaluable when cornered as you can get past mobs that are blocking you. Its also useful for kiting fast moving elites and with tumble uses very little discipline. Finally when act 1 farming I just vault past all the trash and kill the elites
Preparation + Backup Plan = Instant discipline refresh with a chance at no cooldown. Since all our defensive skills use discipline this is kind of a must have. Rune choice can vary but most people use backup plan.
Smokescreen + Lingering Fog = I used to use this a lot more than I do now. Its the only thing we have for breaking CC so its still on my hotbar. I'm thinking of changing the rune to something else though as I really do only use it for CC now, hardly ever tank with it up because it lasts for half the duration of shadowpower with the same disc cost.
Shadowpower + Gloom = 65% damage reduction and 20% lifesteal for 3 seconds, can be chained with enough disc. So long as the lifesteal is outhealing the incoming damage you are effectively invincible.
Archery = required for this playstyle really since it adds so much damage
Steady Aim = 10 yards is not far in D3, so its nearly always on. 20% more damage
Tactical Advantage = Invaluable for kiting, especially fast affix champs. If you are better at kiting than me you can probably lose this one! Makes Act 1 elite farming much faster as you can just sprint through all the trash.
With the stats I have (posted above), there is nothing in Act 3 that can 1 shot me apart from those fat blimp things that fling fireballs which are relatively easy to dodge. Most stuff I can just tank down with Shadowpower/Gloom including named packs other than Phasebeasts and the reaver guys with the big overhead axe attack thing. I am still able to kite effectively due to high dps xbow and movement speed as well as vault with tactical advantage passive. 48 max discipline + preparation means I can burn disc using skills for a long time
Anyway I hope this proves to be of some use. If people have questions feel free to post here or add me Brokkah#2761 and I'll do my best to answer them.
