Not quite sure why so many intel fanboy's are raving at people buying BD. Sure intel is better but why not buy them the mobo and CPU yourself then if you so stark raving mad over it.
Once again some random guy getting confused and interpreting "Bulldozer suck=AMD suck", despite people are specifically criticise the CPU not the company...Not quite sure why so many intel fanboy's are raving at people buying BD. Sure intel is better but why not buy them the mobo and CPU yourself then if you so stark raving mad over it.
well most people here know i was a AMD fanboyNot quite sure why so many intel fanboy's are raving at people buying BD. Sure intel is better but why not buy them the mobo and CPU yourself then if you so stark raving mad over it.
then why the need to post a thread " happy BD owers??" whats the point??
he known this would happen when starting a thread like this...
whats he gonna get out of this thread if the only BD owners say yes im happy
as i said above i had both a PII 1090t @ 4ghz and a BD 8150 @ 4.6ghz and tbh if had to choose between them i'd take the 1090t any day.
The answer to his question?
Even without Intel in the picture, Phenom II X6 is still a better gaming and consumer level CPU than the 8 cores Bulldozer...get that through the thick skull of yours.
Also as someone has pointed out...if AMD had released something like a Phenom II X8 on 32nm, it would have been a more attactive product than Bulldozer, as it would mean higher IPC, AND most likely can clocked up to 4.8-5.0GHz rather than 4.0-4.2GHz on the 45nm Phenom II. And also unlike Bulldozer, the Phenom II would have REAL 8 cores...
BD is designed for specific usage which the X6 lacks in. Understand that yourself...
what (very) specific usage might that be and what is your source for this please?
Not only that...they probably still thinking that Bulldozer FX-8 got 8 REAL cores...His imagination.
Ironically AMD's strength is also its own weakness, due to its scaling from the shared resources, so in heavily threaded situations, it's not that much faster than a Phenom II X6, and is amplified by the fact a Phenom II X8 would perform better than the FX8.
Why people buy the FX are beyond me, they'll continue to justify it, while justifying to themselves they're not justifying their purchase.
to clear this up the Bulldozer FX-8/6/4, don't have separate resources for each core. example the FX8 yes has 8 cores but theres 2 cores per module and they share the resources. the PII performance a lot better because each core has separate resources.
	IPC can only take one so far - yes i didn't mention it but was hoping someone of your calibre sir would understand
AMD chips are always cooler than Intel (saying that I'm referring to phenom days as I don't know how hot the BD chips can get) - I believe 52 Degrees C is where AMD chips stop - whereas Intel goes all the way upto 80!!
I've always said (even having shunted BD) - That mowar cores is the way to go. Intel are just denying the inevitable for now and milking us for all they can - as they are the ones who's software compilers are used the most - hence why BD will be under-utilised. As soon as AMD get on top of this or apps become more and more truly multi-threaded - AMD will be competitve again in the performance front - me waits patiently for now.
By the time games can use 8 cores, Intel will most likely already have released 8 core CPUs.
