Best way to clean Nike Air Trainers?
A washing machine is fine as long as you use a cool wash, the air system will only be affected by a hot wash as this will cause the air to expand.
If I put them in the washing machine do I turn off spin on the wash cycle? Surely spinning the trainers at 400+ rpm won't do them any good?
Already have and it says put them in a washer but like I said they are air system and don't want to ruin them. Only had them 4 months so aren't that worn down but just want to clean out the nasty odour.
Buy some new ones and wash your feet more often.
Problem solved ;)
They have an air bubble, not a system ;) The air bubble won't pop if you don't put it on a 90 degree wash, so just do a short, cold wash. And put them in a pillow case too.
Seriously.
There, that's me being helpful. Had to happen sometime :)
Should add they have suede on them so wouldn't that get ruined in washing machine? Like I said they aren't that dirty externally. I just want to freshen the insides of them and kill the sweat bacteria.
