The "New Gear/Willy Waving" thread
You are losing 2 mins of light at the end of every day now.
2 weeks, that's half hour of light. (28 minutes)
If that is taken at 9:40 at ISO 12800, you are looking at 9:20 in 2 weeks' time for the same shot, that is if the weather is the same.
How would that look printed on a canvas? i guess the texture would hide a lot of it.
I could never shoot that high, though. 3200 is my max :P
Well at 50% magnification the file is still pretty big and it hides the noise well, so if the print or canvas isn't really huge the noise shouldn't be an issue.
Below is a 50% crop.
For me though, these types of high iso files will only be printed in albums so the noise will be hidden by the size reduction.
Cheers Raymond, that's actually very useful for me to know.
The wedding is at the brides parents house/garden, so it's not like it has a traditional reception that has lights...
It's lucky that my other weddings start much earlier...
I mean 9:12, not 9:20.
21st of June and 21st December are the key dates when the days get shorter and longer.
You can get charts online or apps to tell you sun rise and sun set times but it's easy to work out.
Each day you gain/lose 4 min, 2 min either end.
Check weather. A bright sun set makes a big difference.
The summer/winter clock change means knocking an hour on/off from the day before.
Looks complicated but it's easy.
Brand new Canon 60D & Sigma 105mm DG Macro OS HSM *splooge*
Arrived at my work desk today, still charging the battery but still not getting much work done!
I have finally bought one, just in time for my wedding tomorrow. The only non-L lens that will actually get any use (I have the 50 1.8 but don't use it).
35L, 85 1.8, 135L - Should sort me out for some time :) + the 24-70L
Work and the weather are destroying any photography time I had planned of late so the best way I could think to give me a kick was to spend a few hundred sheets on some new glass.
Couldn't decide between the 2 of these so I bought them both :D
Been drooling over the 300 2.8s for a while, managed to bag this off the bay for a decent price, once I find a Sigma TC and some of that elusive sun I'll be using it for jets :D
So the film scanner I bought finally arrived (Plustek 7600i), rescanned a few negatives and I'm quite pleased with the jump up in quality. Because of the way I work it isn't even much slower than my V500:
V500:
7600i:
Nice :) I want to see more! I was thinking of getting one of these...
Here are some more negscans, 1st is Superia 400, 2nd is Ektar 100, the last two are Ilford Pan F 50. It took 15 secs for a preview, 1:50 for a scan that had two passes (multi exposure or some IR scratch removal) - a single pass clocked in at under a minute, but my negs are really dirty. :lol:
The workflow went like this: Vuescan -> Photoshop CS6 -> Dust/Scratch cloning (not much of an issue with colour negs) -> Curves/Levels -> Resize -> Smart Sharpen, remove lens blur
http://i.imgur.com/wtspH.jpg
http://i.imgur.com/XpggG.jpg
http://i.imgur.com/vMqsi.jpg
Can't wait to see what Plustek's new 120 scanner will be like.
** Please resize to no more than 1024px wide before replacing image tags - thanks **
I recently bought the new 8200i SE, didn't know about a new 120 scanner... sounds interesting.
Good scanners for the money.....
