anyone here premium?
Had an odd game last night in my is7 where a team mate in a dead is8 called me a bad player with lots of luck. Just told him to look at my stats and didn't get any reply.![]()
Spuj1988, if you know how to play you can do ~800xp on average per battle with premium. 60k XP in a day is doable but only with higher tier tanks where u get nice dpm and good guns.
Max out the XP by doing dmg to tanks of at least your tier or higher. Of course make sure you hit and penetrate tho![]()
Just bought a Lorraine... jesus christ this is 1 hell of a grind. Costs almost 100k just to get the engines!
Unless you really want to elite the lorraine just skip the last engine, I tried it in the test server and for 36k xp is not worth it. Slightly better acceleration but you are already quick enough and getting to top speed isnt an issue. Not to mention you are a massive box compared to the AMX-13s so rushing ahead to scout is not as viable so more often than not the extra speed can kill you if you aren't paying to much attention.
Only 10k now away from my Batchat right in time for Tier 10 meds, loved all the French lights/meds from T5 up but damn can't wait to get away from the horrible accuracy nerf the Lorraine gets with the 100mm after shooting/during movement.
EDIT: Also woo for whoever made the clan logo!
. The forums have probably stradled the lorraine nerf although I don't think that would explain the payload loss. I found the engine to be a nice boost but I managed to grind most of it before the nerf and it was brilliant; post nerf I thought it was awful. I never got to play the BC before the nerf.
PlanetWOT has the lorraine as the tank with higherst win ratio although I think it is due to its pre nerf awesomeness.
We tend to use 13 90s in Tier VIII companies as scouts (note to self to re-buy one).
