Well i have gone and ordered it!
Mine scored 1793 in heaven bench out of the box, has a asic value of 72% and stock voltage of 1174mv. Looking forward to overclocking seeing what it can really do. Highest temps so far 58° and idle of around 30°.
The higher the number means less voltage is needed to run gpu at its default freq, higher generally means better o/c on air and more voltage headroom to play with.
Lower values are ment to be better o/c when gpu core put water cooled.
Seems to be a bit iffy how this is being calculated currently as some people had values over 100% which shouldn't be possible.
Plus in a few recent updates of GPU-Z people reported receiving different results with the same hardware so I wouldn't put too much faith in this just yet.
Hi again just got my card delivered to my mums, where I am at the moment, need to get home and install!
Anyway can people confirm that have this card that you only get power cables?
I thought I saw a vid where you get monitor adapters/leads, but I have also seen vids where it's just power leads!
Also what version CCC drivers are you using?
Thanks
Me again I take it the drivers/CCC I have installed for my hd 6970 do I just use them for this card and it auto detects?
Or are there versions that are more stable for the 7970?
Thanks again
It's the term used to describe the electronic "leakage" that a chip and/or board has. A higher value means less leakage therefore less voltage is needed.
Sounds like the sort of thing mines making.. it just started to happen in games, like a electrical buzz! is this common.. really annoying :(
