http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI&groupid=701&catid=56&subcat=
Hope i'm not disappointed!
Hi yeah my CPU should be good enough it's an i5 2500k oc@ 4.3ghzAs long as you got a decent CPU to work alongside it, don't think you would be dissappointed.
The higher the number means less voltage is needed to run gpu at its default freq, higher generally means better o/c on air and more voltage headroom to play with.
Lower values are ment to be better o/c when gpu core put water cooled.
I know i'm being dumb but what does the Asic value mean?
Thanks
It's the term used to describe the electronic "leakage" that a chip and/or board has. A higher value means less leakage therefore less voltage is needed.
Sounds like the sort of thing mines making.. it just started to happen in games, like a electrical buzz! is this common.. really annoying![]()
