Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Do you have to clean the sidewall of the tyre before applying it?
Yes, otherwise you are just dressing the dirt.
I bought the Bilthamber medium clay (only need water as a lubricant, big plus for me) a few months back. Having never used clay before it was amazing to see the difference afterwards.
Heartily recommended.
Thanks for the recommendation Leigh, just bought the Bilt Hamber soft clay, as Ray said people found the medium a little hard to need into shape so decided to try the soft one.
Will a spray wax be sufficient to protect the paint work after claying or is a more traditional style wax preferred?
Ray - Giving snow foam a try soon then?
I use the same snowfoam, it's good stuff although took me a while to get the consistency and ratio of water:snowfoam correct. I've now drawn a small line on the lance bottle so I know how much snowfoam to put in!
Can I see a photo? Or roughly what ratio to water do you use?
