Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
[TW]Fox;22319196 said:Why do you constantly buy so much random stuff? I don't get it.
You must have so much random stuff to clean your Yaris that I bet it won't all FIT in the Yaris. It really is getting quite bizarre. How can you possibly need that much stuff?
It's what they call addiction?
EDIT - in all seriousness. This is THE END. No more until the last lot runs out. FYI, there are no duplicates (strictly speaking). I only have 1 polish, 1 shampoo, 1 sealant, 1 glaze, 1 glass cleaner, 1 liquid wax (bought last year), 1 engine cleaner, 1 tyre dressing, 1 wheel cleaner (threw the acidic one in the bin). The only duplicate is the paste wax - FK1000 and 3G; and the wheel sealant (the spray one is trash) hence the FK1000.
PERL is to fix the black plastic exterior, I have nothing to fix that, it looks grey. Polish can't fix that, wax can't fix that. PERL is the best on the market for it.
But yes, it is a lot, and NO MORE! I have everything for everything, well, apart from tar remover
