But if you get the liquid pro, you'll find temps are even more lower!! why do it twice.
Sounds like good stuff for applying underneath the lid! May give this a go!
Shame i chucked my remaining liquid pro in the bin after what it did lol.
I remember it being quite runny.. any chance of it running off and going under the socket onto the board etc?
Because I have to buy Liquid pro, I have IC diamond for example here!
You put too much on, that's why it ran, you only need half a rice grain for under the lid maybe even less, if you put too much on just use a small bit of kitchen roll and remove it in one direction each time till it looks flat. Try not to get any on the pcb area around the chip as its a bitch to remove...
As soon as you start cutting with the blade your warranty is gone anyway
Intel say it is still in effect if you remove the IHS according to some guys in the oc thread.
They don't though. Its just unclued up operators.
ah ok, thought those operators were giving us the green light to remove them.
Cool, I'll order some Liquid Pro so, project will have to wait till next weekend!
