There's some good deals in here http://forums.overclockers.co.uk/showthread.php?t=18422020
Very impressive!
You forgot the battery graph chart SS though!!!!
Also why the hell does the battery life go up sometimes on the GS 3?(can't really make it out too well, but I think your battery life has raised a wee bit) Unless did you plug the phone in for like a minute?
Roughly how much browsing time? Activity time?
Actually you can still get these stats can't you whilst connected to the charger? Only resets when it hits 100% IIRC?
Is your Wifi connection on the 2.4GHz band? My battery life is good too but less than yours, I connect to the 5GHz bands at home/work though and 3 in general has a bit higher battery draw on mobile network mode due to having no 2G fallback when idle.
Can anyone help please.
Two things I have found to be exceptionally annoying since owning this phone.
1- The autocorrect is just terrible, the keyboard is gash, and I hate the way the punctuation works. Can i install a new keyboard to solve both problems here or is the autocorrect unchangebale?
You'll know if it's 5GHz because you'll be connecting at over 100Mbps (150 max). If it's 2.4GHz then you will only connect at 65Mbps max.
Designed for Hamsters.
It doesn't go up, the line just looks a bit funny in places, I don't know why.
I wasn't really keeping track of exact times, but an hour or so of browsing, 2~ hours of video, 2+ hours of music. I left wifi on the entire time as well! The rest is just Twitter/Flipboard/Facebook/Camera/Amazing Alexo)
Here you go:
snip
I was expecting it to die while I was watching Fringe (at the end), but it soldiered on and survived with 4% or so left.
It's worth noting (as you probably know) that the auto brightness is very aggressive, but it's perfect as I'd have the brightness very low indoors and only really change it when outdoors. The One X doesn't ever drop it under 30%~ or so even when in the dark.
The GPS also came on a few times but that hasn't registered? A bit odd.
Used by some as well.
An hour or so of browsing and only 2% usage?!?!
For me on my S it is 10%:
Have read that the auto brightness keeps the screen dimmer than what most people would like, sense AB is far too over the top as you said![]()
I guess the percentages are skewed a bit due to the cell standby being ridiculously high?
What kind of a mount is that?!
Although after todays mishap maybe the phone is best kept in my backpack whilst cycling....![]()
They seriously need to drop that slogan as well, "designed for humans"![]()
Well just as I thought my GS3 was fault free (apart from the black dots which don't bother me at all) my ear piece emits a rather bad rattle in calls. Some calls have it, some don't.
Could this be a network issue or is it likely to be the ear piece?
Thanks
