***** The Official Galaxy Nexus Thread *****
Ok, get you now:
I just changed the search to Google.com and the pics show up, and and the weather still appears to work. Im gonna reboot incase its cached...
The weather works if I set it to Google.com.
if I say,
"what is the weather in sheffield" I get the weather for sheffield
if on the other hand I say
"what is the weather"
I get the weather for Washington.
Does anyone else's Galaxy Nexus disconnect its PC connection if you wiggle the USB connector up and down?
Just noticed it with mine....connector seems fine, not loose, and its not major, only when i wiggle it myself or it knocks on something...
Mine does this as well, it is annoying. Quite disappointed with the build quality to be honest.
Yeah Google changed some security bits. I had around 4 apps that did not work. I emailed the maker of chromemarks and he made an update and I beta tested it. He has it working now. Viber is still bust.
I'm running JB that was to download after I/O.
Was trying to easy update to 4.1.1 using links from android police linked by Jimlad but it doesn't work...do I need to downgrade back to 4.0.4 ?
Anyone had same problem?
you can just download the 4.1.1 and flash over the top mate.
Any idea if Viber are working on a fix?
i would imagine so, but seeing as JB has just come out it maybe a week or two. the guy fixed the 'chromemarks' app with in 7 days of me emailing him.
I had a look on Viber website and typed in the question....it says that they are aware that it currently doesn't work with Jelly Bean and are working on a fix :-)
What a great sight:
:D
Phew!
Power always seems fine, its just the data that it does it on. Is that the same for you?
Its not a huge problem in all fairness, just something I noticed.
So...whilst the general speed and responsiveness is sorted...as well as the speaker?...I have to say I've noticed a couple of problems or performance issues.
First off we have the live wallpaper performance which I must say is awful. Bubbles for example runs fine until any type of touch sensitive movement begins and the background grinds away quite slowly. So static backgrounds for now it is then.
Also some of the apps now obviously haven't carried across well. RBS app for example now doesn't display balance etc but of course these are the issues before the apps are updated for JB.
The cards I've found have their uses and the fact that when it comes up for work and gives me the correct train times I'm actually quite impressed with it in that regard.
Not entirely sure how the flight tracker will work, assuming if I put my flight code in the description of the task it may find the information but that's something I'll need to mess about with.
I guess a few teething problems to be expected but the live wallpaper performance was a surprise. *not rooted*
Phew!
Yeah, the same here. I've tried a different cable with it as well to make sure it wasn't that and it did the same thing. I guess its just a build defect, not a big one though like you say.
