Hey Guys
We are now offering a full range of high performance graphics solutions that allow you to choose the block that suits your needs.
Picking the best graphics cards in the market and offering full warranty services, OcUK Tech Labs cards are proving massively popular for watercooling beginners and enthusiasts alike.
Why risk slipping with a screw driver, spilling thermal paste on a contact or stress cracking a high priced VGA card? Only our highest qualified members of our team of technical experts configure these graphics cards.
A brief insight into what happens:
OcUK Tech Lab H2O Custom GTX 690 4096MB GDDR5 From £988.97 inc VAT
THE FASTEST VGA CARD ON THE PLANET
The OcUK Tech Lab H2O GTX 690 combines the fastest Graphics Solution on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the mind blowing GeForce GTX 690 4096MB, the OcUK Tech Lab H2O Custom GTX 690 allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
This graphics card comes complete with your own choice of VGA block from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
- Your selection from the best graphics card blocks on the planet!
- PLX PCI-E 3.0 Bridge Chip (Gen3)
- Core Clock: 915MHz (GK104) x2
- Core Boost Clock: 1019MHz x2
- Memory: 4096MB GDDR5 (2x 2GB)
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 512-Bit (2x 256-Bit)
- Processing Cores: 3072 (2x 1536)
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 3x Dual-Link DVI-I, & 1x Mini-Displayport
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 300 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
From Only £988.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX 680 2048MB GDDR5 From £526.97 inc VAT
The OcUK Tech Lab H2O GTX 680 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 680 2048MB, the OcUK Tech Lab H2O GTX 680 allows for incredible overclocking potential on an already outstanding graphics card.
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1058MHz
- Memory: 2048MB GDDR5
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2012MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- Card Dimensions: 270*111.15*38.75 mm
Warranty: 3 Years
From Only £526.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX 670 2048MB GDDR5 From £397.97 inc VAT
The OcUK Tech Lab H2O GTX 670 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 670 2048MB, the OcUK Tech Lab H2O GTX 670 allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
From Only £397.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom HD 7970 3072MB GDDR5 - AMD 3 for FREE Promotion From £472.97 inc VAT
The OcUK Extreme H2O Radeon HD 7970 combines the one of the fastest single GPU cards on the planet with the most effective cooling solution. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent Radeon HD 7970 graphics card, the OcUK Extreme H2O Radeon HD 7970 allows for incredible overclocking potential on an already outstanding graphics card.
Features:-
• Your selection of the best graphics card blocks on the planet!
• Hugely overclockable
• Vastly cooler running than previous generation
• Quieter running than previous generation
• Compute Power: 3.5 TFLOPS
• Core Clock Speed: 1010MHz
• Primitive Rate: 2 prim / clk
• Shader Architecture: GCN
• Stream Processors: 32 CU / 2048 ALU
• Texture Units: 128
• ROPS / Z-Stencil: 32 / 128
• Frame Buffer / Memory: 3GB GDDR5
• Memory Width / Speed: 384 bit / 5500MHz
• Load / Idle Board Power: <300W / <3W
• Power Connectors: 8-pin + 6-pin
• Display Outputs: 1xDVI + 2x mDP + 1x HDMI
• 3yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
From Only £472.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom HD 7950 3072MB GDDR5 - AMD 3 for FREE Promotion From £378.92 inc VAT
The OcUK Extreme H2O Radeon HD 7950 combines a blisteringly fast and efficient single GPU card with the most effective cooling solution available. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent Radeon HD 7950 OC graphics card, the OcUK Extreme H2O Radeon HD 7950 allows for incredible overclocking potential on an already outstanding graphics card.
Note - The waterblock fitted to this card will be EN Nickel Acetal.
Cooling: Your selection from the best graphics card blocks on the planet!
Memory: 3072MB GDDR5
Memory Clock: 5000MHz (effective)
Memory Interface: 384-Bit
Shaders: 1792
Bus Type: PCI-Express 3.0
Display Connectors: 2x Mini DisplayPort, HDMI, DVI-I
Crossfire: Up to 4 Way Support
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
From Only £378.92 inc VAT.
ORDER NOW
- We open the graphics cards and stress test it to ensure that there is no risk of a DOA GPU.
- We fit the graphics card water-block of your choice to the card using high performance thermal materials.
- We pack the card up in original packaging and additional outer packaging to protect your investment
- We provide warranty for the first year direct and honour warranty claims up to 3 years.
- A team of trained experts are available to assist on-line or over the phone for anything from installation to troubleshooting
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
Warranty: 3 Years
ORDER NOW
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
ORDER NOW
Features:-
• 3yr Warranty
ORDER NOW
Shaders: 1792
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
ORDER NOW
