** BRAND NEW OCUK TECH LABS GRAPHICS CARDS - CONFIGURE YOUR OWN! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hey Guys
We are now offering a full range of high performance graphics solutions that allow you to choose the block that suits your needs.
Picking the best graphics cards in the market and offering full warranty services, OcUK Tech Labs cards are proving massively popular for watercooling beginners and enthusiasts alike.
Why risk slipping with a screw driver, spilling thermal paste on a contact or stress cracking a high priced VGA card? Only our highest qualified members of our team of technical experts configure these graphics cards.
A brief insight into what happens:
  • We open the graphics cards and stress test it to ensure that there is no risk of a DOA GPU.
  • We fit the graphics card water-block of your choice to the card using high performance thermal materials.
  • We pack the card up in original packaging and additional outer packaging to protect your investment
  • We provide warranty for the first year direct and honour warranty claims up to 3 years.
  • A team of trained experts are available to assist on-line or over the phone for anything from installation to troubleshooting
OcUK Tech Lab H2O Custom GTX 690 4096MB GDDR5 From £988.97 inc VAT
THE FASTEST VGA CARD ON THE PLANET
The OcUK Tech Lab H2O GTX 690 combines the fastest Graphics Solution on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the mind blowing GeForce GTX 690 4096MB, the OcUK Tech Lab H2O Custom GTX 690 allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
This graphics card comes complete with your own choice of VGA block from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
- Your selection from the best graphics card blocks on the planet!
- PLX PCI-E 3.0 Bridge Chip (Gen3)
- Core Clock: 915MHz (GK104) x2
- Core Boost Clock: 1019MHz x2
- Memory: 4096MB GDDR5 (2x 2GB)
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 512-Bit (2x 256-Bit)
- Processing Cores: 3072 (2x 1536)
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 3x Dual-Link DVI-I, & 1x Mini-Displayport
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 300 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
From Only £988.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX 680 2048MB GDDR5 From £526.97 inc VAT
The OcUK Tech Lab H2O GTX 680 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 680 2048MB, the OcUK Tech Lab H2O GTX 680 allows for incredible overclocking potential on an already outstanding graphics card.
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1058MHz
- Memory: 2048MB GDDR5
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2012MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- Card Dimensions: 270*111.15*38.75 mm
Warranty: 3 Years
From Only £526.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom GTX 670 2048MB GDDR5 From £397.97 inc VAT
The OcUK Tech Lab H2O GTX 670 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 670 2048MB, the OcUK Tech Lab H2O GTX 670 allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
From Only £397.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom HD 7970 3072MB GDDR5 - AMD 3 for FREE Promotion From £472.97 inc VAT
The OcUK Extreme H2O Radeon HD 7970 combines the one of the fastest single GPU cards on the planet with the most effective cooling solution. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent Radeon HD 7970 graphics card, the OcUK Extreme H2O Radeon HD 7970 allows for incredible overclocking potential on an already outstanding graphics card.
Features:-
• Your selection of the best graphics card blocks on the planet!
• Hugely overclockable
• Vastly cooler running than previous generation
• Quieter running than previous generation
• Compute Power: 3.5 TFLOPS
• Core Clock Speed: 1010MHz
• Primitive Rate: 2 prim / clk
• Shader Architecture: GCN
• Stream Processors: 32 CU / 2048 ALU
• Texture Units: 128
• ROPS / Z-Stencil: 32 / 128
• Frame Buffer / Memory: 3GB GDDR5
• Memory Width / Speed: 384 bit / 5500MHz
• Load / Idle Board Power: <300W / <3W
• Power Connectors: 8-pin + 6-pin
• Display Outputs: 1xDVI + 2x mDP + 1x HDMI
• 3yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
From Only £472.97 inc VAT.
ORDER NOW
OcUK Tech Lab H2O Custom HD 7950 3072MB GDDR5 - AMD 3 for FREE Promotion From £378.92 inc VAT
The OcUK Extreme H2O Radeon HD 7950 combines a blisteringly fast and efficient single GPU card with the most effective cooling solution available. With features such as cinematic DirectX 11 graphics, AMD's Eyefinity Technology and all solid capacitors. .You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent Radeon HD 7950 OC graphics card, the OcUK Extreme H2O Radeon HD 7950 allows for incredible overclocking potential on an already outstanding graphics card.
Note - The waterblock fitted to this card will be EN Nickel Acetal.
Cooling: Your selection from the best graphics card blocks on the planet!
Memory: 3072MB GDDR5
Memory Clock: 5000MHz (effective)
Memory Interface: 384-Bit
Shaders: 1792
Bus Type: PCI-Express 3.0
Display Connectors: 2x Mini DisplayPort, HDMI, DVI-I
Crossfire: Up to 4 Way Support
HDCP: Yes
DirectX 11: Yes
Open GL 4.2: Yes
Eyefinity: Yes
Powerplay: Yes
AVIVO HD: Yes
Warranty: 3 Years
From Only £378.92 inc VAT.
ORDER NOW
Good idea guys. Always good to see products that help people get into watercooling. I don't think attaching a water block poses too many risks personally, but the warranty on these cards is great. As a lot of warranties are void when you change the stock cooler, I believe?
Would be great if you could offer a service in the future whereby customers can select a graphics card and choose from a selection of waterblocks, assembled to order.
ouch at the price of the 680 can get the evga and xspc for 464 off your very website while keeping the evga warranty even with 8 quids worth of mx4 50 quid for you to unscrew a block and screw another down seems like a lot, not that having the piece of mind isnt valuable but hardly a tricky job considering the enthusiasts this is aimed at
Does the aquacomputer block fit on the Palit/Gainward 670's with the different vrm area?
no. we use an MSI card for this reason.
many companies have warranty void indicators on their cards to
you are forgetting that the evga pricing is temporary though. this will be a very cheap option when it is back up.
if it doesn't, then we will find a solution to make it even better value for money.
I was wondering because the core clock is listed as 1006 which is the palit jetstream and gainward phantom. I sent an email to aquacomputer, they said they can't be sure if it will fit those cards but 'it should'. I know for certain that the EK block will fit them though.
Hi,
I would like to buy the GTX 670 card, but first I have two questions.
For the GTX 670, all waterblocks are in combination with MSI cards? Or you use other manufacturers with different waterblocks? Because the core clock you specify in here does not match the core clocks of the two available GTX 670 cards on the MSI website. If you use cards from multiple manufacturers, I would like to choose that waterblock which comes with a card of my prefered manufacturer.
You specify warranty length for all cards, except the GTX 670. Is it 3 years as well? If a card needs to be sent for RMA, is it your company that provide the warranty service? I presume you void the warranty of the manufacturer by removing the stock cooler.
Thanks.
OcUK handles all the warranty for the entire duration stated and I believe OcUK have an agreement with MSI allowing them to take the cooler off and keep their warranty
Who gets to keep the stock cooler? I'd really like to know if once I've bought one I can put it back to stock in the event I decide I want to put it in a system without a loop. I have a lot of kit, both with WC and air.
we keep it generally but you can request your stock cooler to ship with your card if you like.
This pretty much, it is because we hold the warranty of the modified cards. If you lose the screws we can't get the supplier to replace the card for us long after we've replaced yours.
We can of course should you want to sell the card at a later date forward them onto you. As we will keep all parts for the duration of their warranties, 3 years on average.
where are you hiding the custom 670s that have the same spec as the custom 680s thought the 670s only had 1344 processing cores but if the 670s have got the 1536 then can i have 1 please :)
I worry if someone is not even capable or afraid to fit a wc block to a gpu how on earth are they able to fit it into a custom watercooling loop?
a block can be finecky to fit, some people simply may not want to waste time on fittng the blocks :)
It also in some cases works out cheaper to buy a tech lab card then buy card+block+paste+backplate ;)
Not to mention you don't have to be on edge waving a screwdriver around your new £300+ worth of GPU.
