Had a play with mine now and i wanted to ask,do any of you find the screen kinda 'meh' in that it looks fine but doesn't really look all that great,it does indeed look kinda dull as a professional reviewer put.
What are you comparing it to?
I only used mine for a very brief period earlier but I noticed the screen looked rather dull. Colours didn't seem to pop at all, but that could ofcourse be because I didn't tweak any brightness settings.
its the Nvidia chip,i have the toshina AT100 with Tegra 2 & its dull too.i have noticed Nvidia always made displays appear rather dull & colours washed out.
the samething goes for Ps3 (nvidia gpu) when compared to xbox360 which has Ati gpu. hence why Sony is going with AMD/Ati for Ps4.
The HTC One X says that's rhubarb... that's so bright and vibrant it'll melt your retina's at 20 paces on maximum brightness..
Lol @ it's Tegra 3's fault.
I think I would rather one of these, much more comfortable to hold while in bed etc.
Just been playing about nor for the past couple of hours, one thing I have to keep telling myself is the price I payed for it, no way does it feel or respond as though it was under £200.
Does anyone have a link to a good tutorial in how to side load Flash from an older version?
Does it involve rooting or anything cause I really wouldn't fancy that!
For the kind of stuff I'd do on a tablet about 7 inches is about right....7.7 inches to be exact
You can't get any real work/stuff done on these things, it's just a expensive shiny toy.
Just install it and run a browser that supports it (I'm using Dolphin HD).
Its really just as a workaround to use iPlayer, via browser, will that work?
