To Tom_d's standards? Probably not!
Actually you're right! I just noticed a fault!
I've run out of DSR time as well!
Fair enough, but I think it's worth checking out to see if you have the lose screen issue as I believe Google themselves are telling customers to return, as it could put added pressure on the screen over time causing damage.
Only if someone has the patience and time to log in / out of apps to buy all the appsmore free £15
rumour is if you sign in with another google account on the nexus you get another £15
Only if someone has the patience and time to log in / out of apps to buy all the apps![]()
Actually you're right! I just noticed a fault!The transparent serial sticker on the back is not aligned dead centre!
If you examine the thing, left side on, and peer at it really hard in good light there is a 2cm area where the screen cover is raised by a tiny fraction of a mm on mine. And I mean tiny. When I press the screen there it flexes down flush.
[ASSE]Hinchy;22378278 said:Mine has arrived todayHad it delivered to work.
How can I get BBC iPlayer working on it so I can watch the golf?
Ace!!!!!! No raised bevel or screen so far, bezel sits perfectly, perfunctory screen test is good, it's a hand friendly form, somewhat smaller than the SGT 7.7, very handy as said by others the back feels nice.
No movement in the usb socket.
So has anyone here actually got a flawless N7 without any defects etc?
Make it nice and clear on here when you do.
Installed v10 then v11 flash, still not getting anywhere, installed firefox still not getting anywhere.
Installed iplayer, get redirected to a iplayer your not supported page!
