Buying one of these at the moment seems to be like rolling a dice and seeing which fault you'll get.
Got to be about 1 in 5 that has an issue. Not ideal, but get a gooden and it's a superb device for the price.
Not sure they should have put their "Nexus" branding on it.
Tesco still have stock online, they must have been allocated a lot of units.
Yeah, they got a boat load. They are on their second batch though, they did sell out once. I will compare the lot numbers when I get the new one, see if it is a sign of a different manufacturing batch.
Is yours showing as despatched yet. I hope my replacement arrives tomorrow as I have chosen to work from home at my mums tomorrow.
I checked and it shows the new one has been dispatched and have a new order number entirely.
If you sign in online , it should show your new order details. Just shows a value of £0.00 paid.
Christ I've never seen so many bad units
Yeah I have that but it has at the top item is labeled to be dispatched
Hello again overclockers,i just wanted to say here that my nexus 7 has died
Was using coolbooks to read some pdf files i had and the screen flickered like mad,buzzed now it wont turn on at all.
Shame i will not be waiting for a replacement after waiting so long to get my hands on this,i hope google aren't as bad as giving refunds as they are at shipping...
FFFFFUUUUU!
Another one bites the dust.
After me thinking mine was perfect, it's got a screen fault. Weird one, only happens in landscape mode and doesn't occur in every app. Basically when I grip the tab with my left thumb in an area just below the bottom left hand corner of the screen, it disables touch input to the screen. Great. And the buyer of ecstasy where I bought it isn't expecting delivery until 10th August.
FFFFFFFFFFFFFUUUUUUUUUUUU!!!!!!!!
In stock at Tesco. I bought from same place as you and they collected and will now process a refund. Easy enough. Purchased from Tesco and so the refund should pay off the second purchase.
Might do that then. Supposing the Tesco one is faulty, do they do the same and pick it up?
Just do collect at a store and then you can always drop it off for an instant refund (the refund itself takes a few days).
