HTC One X was similar. First batch of those all had weird screens. Either loose, yellow blobs etc.
I got one of the first units & mine is A1 - So not all, as you state.
FFFFFUUUUU!
Another one bites the dust.
After me thinking mine was perfect, it's got a screen fault. Weird one, only happens in landscape mode and doesn't occur in every app. Basically when I grip the tab with my left thumb in an area just below the bottom left hand corner of the screen, it disables touch input to the screen. Great. And the buyer of ecstasy where I bought it isn't expecting delivery until 10th August.
FFFFFFFFFFFFFUUUUUUUUUUUU!!!!!!!!
Have to say, the occasional screen flickering is annoying as hell, might well be sending mine back due to it.
I've no idea, it would depend on the cause of it and either way, I am not sure I particularly wish to wait on a software fix that may or may not solve the issue at some point in the undefined future.
Nexus 7 #1 (8GB) Play Store - 4 dead pixles (3 on upper right and 1 center)
Nexus 7 #2 (8GB) Play Store - loose screen glass on bottom left and right
Nexus 7 #3 (16GB) Sam's Club - straight line of dead pixels from left to right
Nexus 7 #4 (16GB) Sam's Club - spongy screen glass sticking up 1mm
Nexus 7 #5 (16GB) Game Stop - broken USB connector, can't be charged
(all of the above five were returned for refund)
Nexus 7 #6 (16GB) Play Store - very slight spongy glass, but I'm giving up and accepting it as it
Sure that isn't you tom?
Couldn't that be corrected with a software fix though?
FFFFFUUUUU!
Overall mine has been great except this weird bug i get where the screen seems to go black ingame after a while. It was doing it in "shoot the apple" yesterday and was very annoyingit only does it ingame, not even in the menu's
Then i loaded it up a few hours later and it was fine but eventually it did it again. Might be a problem with that specific game..
The contrast things happened to me once or twice, but its more like some setting that applies in 3d apps and it doesn't return to normal straight away, but does after loading another app. I'm assuming its a software fault tbh...I had an issue with mine from Tesco. Had the screen washout, almost like the contrast had been truned up and ghosting.
Finally got hold of them yesterdya having ordered it thursday, got a replacement coming tommorow.
I've only had the one device so far, thankfully.
Would be clinically insane by now!
