- 28 Dec 2009
- Wales
Cheers for the advice regards coolers. Awesome build mate. Nicest I have seen on here for a while!
Cheers guys much appreciated
@ Edward78 an mATX board would still have plenty of breathing space in the TJ08-E
Damn, that looks boss! I am sorely tempted to copy your build, even though I don't really need to upgrade at the moment. I just like the idea of a small but powerful machine, kind of like how mobiles having gotten smaller and more powerful.
Edit: Any chance you could take a photo with something next to the case for a sense of scale? Like maybe a DVD case?
That is an awesome build. I want to do something similar, my only issue is my 3.5" HDD.
I notice it has holes at the bottom to secure a 2.5" (SSD, in my case). Do you think adding a 5.25" to 3.5" adapter will hold my HDD up top? So i don't have to use the HDD cage?
I see the case can actually fit micro-ATX boards, so why did you stick with ITX? I am trying to decide on a MB for my theory-build, and micro boards must be better than ITX ones right (if you can fit them in your case)?
On another note, I have been deciding whether to get a water cooler like yours, but I read that air coolers might have better performance and water blocks were just for looks. Is this why you went with water? Do you reckon a tower cooler could fit in there ok?
Looks great, 2nd time I'm seeing this.![]()
Now stop showing off mate![]()
I see, thanks for the advice. I have a build in mind now, the cooler is just the last undecided piece. Next I need the courage to click buy on the £500 upgrade! Also need to sell my old case, MB and Q6600.
Lmao![]()
Now there's a familiar face![]()
First of all the forget the notion that waterblocks are just for looks, that is an absolute myth; Hybrids such as the the Antec KÜHLER H2O series or Corsair H series (though I'd avoid the Cosair H series as they are renowned for noisy pump problems) are far more efficient than air cooling and full blown water cooling is far more efficient still.
I'll be upping my 620 to the 920 in the near future purely as the Ivy Bridge chips run hotter, the 620 is ideal for Sandy Bridge chips.
Also fan choice is key and I'd recommend Scythe GT series.
Would a standard air cooler fit the case?
Yes
Though I'd recommend you look at the Silverstone website to be sure as to the maximum height tower it will accept.
