If your tv has ethernet you'd be better going for a wired connection, even using something like a set of homeplugs.
Edit: the 212j would have done all the above
what model tv do you have? i use a hama wireless dongle but it only works on certain types of samsung tv's
What hard drives did you get? Thinking of swapping out my WD Green drives for a set of reds.
Those blues should be plenty fast enough mate.
Do u know if u can use SSL encryption when using it as a ftp server.
for sharing files to friends.
Will it best to use disk station manage 4 or even use the Beta 4.1 ???
Yes you can
I have been using 4.1 for a week or two now and find it really good. Not encountered any bugs during my use yet. I think you will be ok with the beta mate
