Synology drive
28 Nov 2004
Just purchased a Synology DiskStation DS212+ 2-bay All-in-1 NAS Server
waiting on delivery does anyone know if this will be anygood.
its the 2ghz cpu version. thx in response, hope i made a good choice ;)
If your tv has ethernet you'd be better going for a wired connection, even using something like a set of homeplugs.
Edit: the 212j would have done all the above
Yeah was looking at that but wanted something with faster read write speeds.
will be looking into getting some ip camera as well.
what model tv do you have? i use a hama wireless dongle but it only works on certain types of samsung tv's
Do u know if u can use SSL encryption when using it as a ftp server.
for sharing files to friends.
Yes you can
Will it best to use disk station manage 4 or even use the Beta 4.1 ???
I have been using 4.1 for a week or two now and find it really good. Not encountered any bugs during my use yet. I think you will be ok with the beta mate
Yes you can
Downloading 4.1 beta now ;) only problem i had was u cant revert back to version 4. but if its good im good to go with that ;) thank you
Got most of it running just to make sure im ssl secure can u tell me in DSM settings i have ticked Enable Https connection.
so when a friend uses Filezilla will that be fully ssl encrypted. thx in response ;)
