scotslad
phew... a lot of questions...
I'll try and answer as best I can. Though I'm no expert, just an interested amateur like yourself. So please excuse me if someone with a more in depth understanding reads this and thinks I'm being a bit simplistic.
Question. "Tell me first please, surely you guys arent telling me cause I have defragged my SSD that I have effectively cut a chunk off its life ?"
Simple answer... unluckily yes.
Long answer... Each NAND cell can be put through a limited number of erase cycles (usually around 3,000/5,000 cycles). So in effect each time you write to a cell, you are using up part of its life! In normal day-to-day use this should not be an issue, as the firmware in the drive does something called "wear levelling" that to an extent mitigates this. So in normal use, an SSD should hopefully remain usable for it's intended life. It's a complicated issue and if interested, you need to do a bit more reading.
You said. "surely that wouldnt have dont any permanent damage man, if so, I wish someone would have mentioned this very very strongly to me before now as its too late now".
I think the OCZ FAQ that I pointed to earlier on in the thread does in fact stress this quite strongly! Though this was in reply to someone else I think.
http://www.ocztechnologyforum.com/f...BC-for-OCZ-SSD&p=567574&viewfull=1#post567574
Question. "Also, are youz saying too I have screwed my drive just by doing the benchmark test too ??
I mean, I ran some more than the ones I posted, maybe about 10, not exactly sure "
Answer. I'm not sure I'd say "screwed" but you've certainly both shortened its life slightly and probably caused the firmware to throttle the performance back as well (to protect the drive). Not too sure how much of an effect it will have had but it will have had one! 10 consecutive speedtest and 10 de-frags will not have done it a power of good.
TRIM and garbage collection over time will start to recover the drive but as to whether it's had a permanent impact, I don't know enough about how the firmware works in the Vertex 4 drives. The only real way to get the drive back to "out of the box state", would be to Secure Erase the SSD and either re-install Windows and STOP running loads of speed test and DON'T de-frag your SSD (it's pointless anyway.. it's the job of the firmware in the SSD to sort out how the data's stored!!!). Or.... backup your current installation, secure Erase the SSD and then recover the backup to the SSD.
As to what a Secure Erase is, this is a command (can be done either via the OCZ toolbox, or via a bootable Linux utility that OCZ can also supply) that is sent to the firmware in the SSD that will then
destructively erase the data. This is the way to effectively re-set your SSD.
As to where to store things. As I've said before, I would stick any application / utility that you think might benefit from the extra speed, on your SSD. As to games... to be totally honest, I don't think you will notice much difference, only maybe on loading times and even that appears to depend on what game and how it loads the data. I have my Steam folder (IE. games) on a separate SSD and to be honest, I can't say that I notice a BIG difference (any?). But again, on a free roaming game (EG.Stalker, Metro 2033) that loads a lot of stuff on the fly as you move around, it might make the transition from one area to another, less noticeable.
As to "Intel® Smart Connect Technology" I suspect your PC simply does not support this. Is it not meant for certain Laptops?
Got to be totally honest, a good read of the OCZ SSD FAQ i
s time very well spent.
http://www.ocztechnologyforum.com/forum/content.php?306-SSD-ABC-Guide
Have fun....
PS. No disrespect intended.... But this is in fact why I've made the comment "that SSD's are not quite as plug-and-play as mechanical HD's" a number of times over the last couple of years to people. No great issues, but I think you do need to do a little bit of re-search before buying / installing one. As you are not the first person to fall into the traps that you unluckily have.
PPS. I think it's a major testimony to the resilience of these drives, that even after all your speed test etc. that things on the face of it don't look too bad. If this had a Sandforce controller in it, I suspect it might well have looked a little sick by now!
