a week without a computer has given me ideas![]()
errr why when i die does all my stuff vanish instantly?
also iorn spade recipe makes an autumn shrub...
also found some gems that looked like darker blue diamonds called apponite or similar but they vanished when idied.
what are they used for?
They are call Apatite and part of the Forestry mod, there are used in the making of Fertilizer, linky: http://forestry.sengir.net/wiki/index.php?n=Ores.Apatite
As for the iron spade, there are a number of configuration issues with the server outstanding at present as well as server saves and backups needing sorting out, I'd rather wait until these are resolved and implemented. None of these are particularly difficult to resolve or put in place, I guess free time is the issue.
Oi you git! I wondered why my server was down! People were asking in irc what happened to it lol.
Hopefully the last client update for a while - anything else will be server side.
http://www.oxygene13.co.uk/client125c.zip
Fixes:
-Conflicting Block ID's on a couple of vanilla minecraft blocks.
-Can now craft Forestry items (had to roll back a version - the new one doesn't go well with the 4096 block ID fix and/or new version of Forge)
-Removed Crafting Table Mk III, I know this is a super handy mod, but it needs updated to the new forge dictionary and it's causing too many errors and crashes. Will hopefully return in 1.3
-Removed Forestry API from ExtraBiomesXL to fully remove any errors with conflicting API's (already removed from EE)
Added:
- OptiFine Smooth 6 (client only)
- World Saving & Backup plugin (server only - save runs every 40 minutes with a 60second warning. Will reduce if anyone thinks its required)
- Updated RedPower, IC2 & Buildcraft (server only) that include a few minor bug fixes/config options
Closed the other server down for the mean time so I can test multiple worlds locally. Any issues let me know and i'll jump right on 'em.
Great work Steve, you should have a look at the live map if you get a chance, volcano basalt is showing as rubber wood and the lava is not rendered, this is a problem you've fixed before.
The ExtremeBiomesXL mod adds very few new blocks which can be added to dynmap as custom blocks with relative ease, even if you only get the cracked sand and red cobblestone done this will fill in the huge back areas currently shown. Adding the various leaves would also make the map particularly appealing though I imagine the above changes will require rendering to be completely redone.
Minecraft has crashed!
Minecraft has stopped running because it encountered a problem.
--- BEGIN ERROR REPORT 7f65ba77 --------
Generated 05/08/12 14:28
Minecraft: Minecraft 1.2.5
OS: Windows 7 (amd64) version 6.1
Java: 1.7.0_04, Oracle Corporation
VM: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
LWJGL: 2.4.2
OpenGL: GeForce GTX 460/PCIe/SSE2 version 4.2.0, NVIDIA Corporation
java.lang.IllegalArgumentException: Slot 193 is already occupied by forestry.core.BlockSoil@79ec235e when adding forestry.core.BlockSoil@7e062eda
at pb.<init>(Block.java:251)
at forestry.core.BlockSoil.<init>(BlockSoil.java:29)
at forestry.core.config.ConfigureBlocks.initialize(ConfigureBlocks.java:21)
at forestry.core.config.Config.load(Config.java:194)
at forestry.core.ForestryCore.load(ForestryCore.java:52)
at forestry.core.ForestryClient.load(ForestryClient.java:33)
at forestry.mod_Forestry.load(mod_Forestry.java:26)
at cpw.mods.fml.common.modloader.ModLoaderModContainer.init(ModLoaderModContainer.java:351)
at cpw.mods.fml.common.Loader.modInit(Loader.java:263)
at cpw.mods.fml.common.Loader.initializeMods(Loader.java:604)
at cpw.mods.fml.client.FMLClientHandler.onLoadComplete(FMLClientHandler.java:203)
at net.minecraft.client.Minecraft.a(Minecraft.java:426)
at net.minecraft.client.Minecraft.run(Minecraft.java:735)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 8b131558 ----------
Using this crashes Minecraft
LWJGL: 2.4.2
Just re-uploaded the client I just exited out of. Try downloading it once more.
Not sure what’s up really, entire system looks pretty much under load. Looking for straws and broken camel backs. [/qupte]
sounds like an easy fix.
What are ya working on?
