- 23 Nov 2011
- London
How many motherboards have CPUs in the bottom right? :s
By that I meant the bottom right hand side of the socket
I know what a CPU socket is.
But thanks for clarifying your previous comment![]()
Also if I check the 'apply oc at start up option', will afterburner load each time windows starts? Or will it be a registery tweak? Thanks
I would like to thank all the people who have significantly contributed to my green dragon 888 pc build. Thanks to support of good people such as Ethermaster, Blue160, thezakarum and cmndr_andi I have build a good eco pc. Those that I have not mentioned I apologize but I do very much appreciate your help.
Bearing in mind that this build is working but not complete. I still got to put in amongst other things filters, custom quite fans to make it even better. Other improvement suggestions are welcome.
Haz 1.368 is quite high. People usually achieve this oc with about 1.289. Are you sure you needed to go that high?
Lovely oc btw if its stable.
Mine's also greener than Arek's because I bought some of the components second hand![]()
I got my case and screws used to name few. I feel proud of my self to be so good to make make my green dragon 888 fly and kick ass.
Also my stock cpu temps are in mid 30's. Thats how good my cooling is.
Regarding pics, I am not sure if its allowed to post here. It might be against forum rules to post build pics here.
It is definitely allowed, and I think a lot of people would like to see it.
I will only post it if you can find the exact clause that says one can post pictures of build in here. I really like to keep my record clean.
FAQ said:You may post images providing they are hosted by a well known image hosting website, such as imageshack, photobucket etc.. Directly linking to images on other sites that are not expressly for that purpose (known as Hotlinking) is not permitted. Hotlinked images will be removed with an infraction notice issued. Repeat offenders will be suspended. The sharing of images from your own personal web-space is acceptable providing you are the owner and give permission to do so. However, the OCUK moderation team reserve the right to replace or remove any image that is suspicious of being hotlinked or unknowingly hosted by a members personal web-space, as it is not possible to identify those where permission has been granted or otherwise. Such decisions will not be overturned. To avoid complication, we strongly advise that all images are hosted by a image host as mentioned above, which can be easily identified as so. Images containing nudity, adult or offensive material, including swearing is prohibited. Please check your images before posting. No watermarks or URLs for sites containing content that wouldn't normally be allowed such as competitors, adult sites etc. Any images of such nature will be removed and your account immediately suspended or banned. Unless otherwise agreed by the moderation team, images must be no wider than 1024 pixels wide. The only exception to this are images posted intags.
