Right that's it. I'm getting my friends unused 3960x @ 5hz out now, you made me mad![]()
lmao
@ 5hz...This should surpass even the A1200 Amiga
lmao
@ 5hz...This should surpass even the A1200 Amiga![]()
Not on the Heaven 3.0 benchmark
You can also slacken the memory slightly if necessary to get you through as memory is less important than raw mhz.
Well i slackened the memory but ended up overclocking it too lol ( thanks for the tip)
From 1600MHz 8-8-8-24 2T > 1866MHz 9-10-9-27 1T with same 1.5v
Seems stable so far running benches and played a few games so i think maybe its just the drivers i need to update and hopefully they'll be more stable. With the RAM overclock i got my score slightly higher.
Score
P9440 3DMarks
Graphics Score
9137
Physics Score
11805
Combined Score
8979
http://www.3dmark.com/3dm11/4076366
Just gotta wait for those Catalyst 12.8's![]()
New SLI graphics score please Gregster. Don't need to worry about adding the other bits and bobs as CPU was at stock. PCI-E 3.0 (I think) was enabled hence the bump.
http://www.3dmark.com/3dm11/4080552
SCORE
P16984 3DMarks
GRAPHICS SCORE
23179
PHYSICS SCORE
9949
COMBINED SCORE
8739
Updated your Main score but a slight dip in performance from your GFX score, so left the old score you had.
Will probly get a higher score with better drivers soon anyway.. Cheers.Big jump in total score Rusty. Not sure what clock speeds you had though as 3DMark was showing 1601mhz.
Nice score. Good to split the top 3 up me thinks![]()
Locky probably crying in the toilets at work at the sight of it![]()
I'm going to wait for it to be cold and for the planets to align, before my new score.
in other words when I'm not mega busy at work![]()
I hear benching at 4am is also good for temps
Pro tip there mate, i don't give em away freely.
