DPS is too low, all resists probably around half of what they should be. Remove Spike Trap as your using a bow and it's range is too big, you really need a crossbow for it to shine. In its place get Preperation with Battle Scars rune. You could do with a new weapon also, a 900 DPS bow with 100 dex and socket would beat what you're using.
I'm a 2 handed Barb. I can complete Act2 but not really make much progress in act3.
I'm at 40k Health which is relatively low but I do 40k dps and over 100k when using WotB.
You think all resist is that important for a DH? Suppose it depends if you're going tanky or glass cannon, but it's pretty tough to do both unless you have a huge budget.
Well I completed Inferno with 1 weapon and a shield, I did this because it made me very survivable (and I didnt know of any other effective build). Having high resistances, loh weapon coupled with a shield with high block % makes things a lot easier.
However now that I am in a position with better core gear, 2 weapons allows me to use the double WW build. The main points (apart from it being more fun and quicker to farm) are that you can stack a lot more stats if you have 2 weapons. One of the keys to the double WW build is that you want to stack a lot of critical hit damage. With 2 weapons, you have the potential of 400% increased critical hit damage from the weapons alone (if each weapon had 100% base + a gemmed socket). Basically, the idea is that if you are using 2 weapons, your damage needs to be high enough to counter the loss in defense that a shield provides so that things die quickly enough to not cause you too much grief. With the double ww build, this is true but also having ~1000loh+ is very important since the cyclones hit many times a second to multiple targets, regenerating a lot of life and allowing you to survive. If you dont have loh with this build you wouldnt survive.
Just start again as a Monk. Any tips on what gear to go for as only had used the Barbarian so far?
Has anyone sold gold recently? None of mine is selling.
Just hit dex and vita gear until hell act 4, then you can probably start to gear up with a bit of all res to make things a bit smoother. Also I think once you hit mid 40s (someone please correct if im wrong) you can get a weapon with reduced level requirement and basically one/two shot things in hell. Dont think thyre that expensive now.
Unless they changed it since I was last on, cyclones do not work with LOH, they only work with Life steal.
Unless something has changed between now and last night, this is definetely incorrect. Run like the wind and LoH has always worked for me and everyone else who uses that build..
Cant muster the energy to play this at all, sad state of affairs when 900 DPS 1h's with reasonable stats just don't sell day after day =/
Good to hear, might go back to the game soon if I can finally purchase a 1 handed weapon that doesn't cost 50million minimum!
