- 11 Dec 2005
- Cheshire
I have a torsen LSD
What do I win?
What do I win?
I loved my supercharged 1.8iS Mk2 with Gaz Gold Pro.
Unless I was being a total goon I found it next to impossible to get the rear end to step out under acceleration.
On my old E34 the LSD was really, really noticeable. On the MX-5 it wasn't.
Did it wash out a bit on entry to corners (ie, tendency to understeer)?
Sounds like the setup could have done being tweaked a bit. Setup makes a massive difference to how these handle... before I realised (and was a poor-ass student)... on my first mk1 1.6, I used to just stick the rear tyre pressure up to 37-40psi and keep the fronts at 28-30... that was fun.
Also, softening up the front suspension & firming up the rear is a great fun combination.
My 'charged mk1 1.8 (@220bhp) was awesome... you could fling the back end around so easily![]()
Loved? What happened to it?![]()
Yeah it did to a small extent but I only really noticed when off the public road. On a dry road I rarely had an issue with the front end unless it was bumpy or dirty/dusty/greasy. In those latter conditions it was really, really nervous though. Generally speaking, I could turn in as hard as I dared and hold as tight a line as I could hold whilst staying in the seat/car without ever thinking about it.
