I dont get why they would make the game easier. Makes it less fun. The amount of times friends and i have died while laughing our heads off is endless. Wouldnt have had half as much fun if we had just stormed through while only dying once or twice.
Simple. All the whiney farmers want to get as much epic loot as they can with as little effort as possible so they can make money on the RMAH, and if the poor little souls are they're dead, they're not making money![]()
Ok, i've given up on this now. I just can't make my DH good enough to withstand act 2 inferno without dying too often. I'm just bleeding cash due to repair costs. Hours of farming act 1 to try and eke out enough for a small upgrade is boring the hell out of me now. I'm done.
Could be your skill set up also? got a link to your profile? unless of course you are completely done then no need![]()
You should be capable of blitzing Act 2 really, for the most part at least, some packs are just horrible purely because of the mob types in Act 2 (melee serpents for example can be brutal). Add me if you want, can maybe take a look at your skill set up or do an Act 2 farming run and see if I can suggest any pointers.
Some of the elites really are swines to kill though
I rely quite heavily on discipline to sprint clear of packs and get some shots in. Unfortunately if I don't kill them fairly quick, I run out of discipline and i'm a gonner.
Cheers mate, i'll add you in a bit
Have to say that my stats don't look too bad, so maybe i'm just a bit of a rubbish playerSome of the elites really are swines to kill though
Edit: Just checked your profile and holy hell you have some firepower![]()
trying to build an MF set for 1.0.4.You really need Prep (Backup Plan) and Shadow Power (Gloom) if you aren't already using those. If anything takes you to 50% HP you immediately pop Shadow Power, then DPS a bit to get your life up and look around to see what just hit you, then adjust accordingly, you could chain 4 SP's back to back with Preperation and this allows you to pretty much face tank any elite pack.
Also, in my MF geartrying to build an MF set for 1.0.4.
Cheers for the tips.your stats are far better than mine and i'm playing act 2. a few deaths but that is the point of inferno really. you've got like, triple my dps, i think. you're doing something wrong ^^
I don't think that's my true dps though, it only looks high due to one of the skills i'm using.
Edit: Think it's the sharpshooter one
Hmm, this looks fishy.
2x Sage Seekers up for sale, both have the exact same stats. They are also both up for sale for 7,770,000 and both have 1d 11h remaining.
Some kind of dupe?
He's also a very skillful DH, so listen to what he has to say
