- 22 Jul 2012
- London
Helios also has a Phanteks.... and you don't![]()
Only 'cause my case is nouveau riff-raff chic and utterly unworthy... sniff
I've had everything haha. I just use the K2 because it looked the best and allows me to use RipJawZ. The Phanteks is still better.
Saying that, I was the first to start recommending the NH-D14, then the Silver Arrow, then the Phanteks and finally the K2 because I was always first to be sent these coolers in the world /endbrag
You can't go wrong with any of these, and each have their own plus point. The NH-D14 is a good all-rounder, the Silver Arrow the quietest, the Phanteks the best performer, and the K2 the best looker.
Best mounting system I've used and very quiet for how much cooling it does. Phanteks has better colour scheme for sure.
So with the others the RipjawsZ don't fit?
Tall ram-sinks on memory don't really do anything. So don't compromise because of this.
I LOVE the D-14, I have had mine for over 2 years and it's all I'll ever need. It's a very quiet cooler. [email protected] won't go over 63c on P95.
I would go for the Noctua D-14 if I had to buy another I just can't fault it. It's easy to install and keeps me satisfied with air cooling.
The differences in temps between these coolers is negligible unless you are really anal about it. Don't think you can go wrong with any of them. Happy to know my D-14 will last me for a long time.
D-14 is amazing, I don't see how anyone would be disappointed with it. Everything from the price to box and included parts are well worth it. The fans on it are top notch I love them.
Tall ram can usually be installed under the 120mm fan but you have to install the ram first obviously, it's tricky otherwise.
D-14 certainly gets my vote.
Which Q6600 and at what clock, I managed to get 62'C at 3600 with my HDT-S1283.
http://s194.photobucket.com/albums/z46/Dark_Light748/?action=view¤t=400stress30.jpg
Just a Q6600 GO at 3.6GHz, this is without amazing case airflow, 1 intake 1 exhaust in coolermaster silencio. Silver arrow certainly sounds tempting I just don't like the look of it at all.
I wouldn't consider D-14 fans to be noisy at all... at full rpm you can hear it but I can't class it as noisy. It's a shame it costs so much here. £56.05 with free delivery elsewhere, so cheap for this cooler!
