DimasTech Anti-Vandal Switches for your cases
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Stock is landing with us this week. These are great to improve the looks and quality of your system.
DimasTech Push Button Switch (16mm) Alternate Action - Blue LED @ £6.98 inc VAT
Push-Button DimasTech®, 16mm ID, Led Color Ring/Illumination, Power Led Ring 12V, AC/DC, LifeTime 40.000 Hours, Alternate Action
Technical Specifications:
- 2 Contact NO
- 2 Contact NC
- 1 Contact Power Led
Package Contents:
- 1 Push-Button DimasTech®, Led Color Ring/Illumination
Important:
- Alternate Action: The Push-Button is pressed and released once in this position, until the next press.
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Alternate Action - Yellow LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Alternate Action - Orange LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Alternate Action - Red LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Alternate Action - White LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Alternate Action - Green LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - Yellow LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
- Momentary Action: The Push-Button when pressed and released goes back to its original position.
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - Blue LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - Green LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - White LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - Orange LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (16mm) Momentary Action - Red LED @ £5.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £5.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - Blue LED @ £7.99 inc VAT
Push-Button DimasTech®, 19mm ID, Led Color Ring/Illumination, Power Led Ring 12V, AC/DC, LifeTime 40.000 Hours, Alternate Action
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - Red LED @ £7.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - Yellow LED @ £7.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - White LED @ £7.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - Green LED @ £7.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Alternate Action - Orange LED @ £7.99 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £7.99 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - Yellow LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - Orange LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - Red LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - White LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - Green LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
DimasTech Push Button Switch (19mm) Momentary Action - Blue LED @ £6.98 inc VAT
- 2 Contact NO
- 2 Contact NC
Package Contents:
Important:
Only £6.98 inc VAT.
ORDER NOW
I dont get these do these replace your power switches ? on and off buttons at front of case
I would think you need to drill a suitable hole in the case and connect the wires that would normally be attached to the case power button, if you were to use them for a power switch.
You could use them for other things like lighting etc.
so not so easy to install ;) look lush still
They're just switches used for turning things on and off, that look nice.
The anti-vandal bit is due to the fact you would need internal access to be able to remove them.
At last, ocuk selling proper modding gear! Now can you get in the cables required to connect them to your motherboard easily. I have seen them elsewhere :)
