I think wider midi cases are the future. 140mm fans front and rear and more CPU cooler clearance is what we want... and better cable management
yeah i like the wider cases, good they moved to 140mm as well need more air pushing and more silence why not...
my R2 fractual I can barely fit the cables behind it...
Hello,
Thank you for your mail. Very soon Define R4 with window side panel will be available in UK and all other European markets.
Thank you.
Best regards
Fractal Design
Yeah I know. R2 here too. 2x 140mm fans move same air as 3x 120mm fans
bitfenix range are pretty good and silent...
which 14cm?
Thermalright is releasing a new TY-147 on the HR-02 Macho Same fan as TY-140 with balck housing and white blades.
Probably won't fit but...
