- 2 Mar 2004
- SE England
Seems I'm not the only one who prefers the Astra:
Had a sit in one on Sunday at Ford Fair was pretty good, will drive one before I decide but I think my heart is set on getting a Mk.2 RS personally, as I could get a 2-3 year old one and mod it to the spec I want for the cost of a new ST-3.
My ST is at the spec I want it, can't really go any further with it without resorting to an RS engine, which I don't really want to do, would want a better looking car as well as the 100 extra horses.
Eh? The ST has the exact same engine as the RS
I thought the rs was a bit more than that? i.e damping brakes etc etc etc
If it was exactly the same, it would make the same power surely?
Oh yeah thanks for the negative trust comment BTW, really grown up.
It has more capable component e.g. clutch, revo knuckle suspension, turbo, injectors. But all can be fitted to an ST.
The RS clutch and injectors being a very common mod for ST owners, to safely reach the 300+ area.
TBH I'd rather have a Quaife ATB differential instead of the revo knuckle suspension anyhow. Plus sometimes I can't stand the amount of plastic bodykit the RS has.
No, the components of the engine produce more power, ECU, Turbo, Injectors etc. The engine is exactly the same that is found in the ST (B5254T3), which is also found in the 2004-2006 Volvo S40 T5 and 2004-2006 Volvo V50 T5.
Thanks, the trust reflects your attitude to posts I make.
That's like saying my Mondeo 2.0 engine is the same as a BMW 2.0 engine...because they both have four cylinders and are recorded as 2.0L engines. :/
Really?
Not quite.
Believe its lower compression due to different pistons and rods.
Different inlet
Different injectors
Different liners possibly?
That said, Theres no reason why you can't safely get the same power in an st at all.
So its a bit of a moot point![]()
Really?
2.5t RS has a compression ratio of 8.5:1 and the 2.5t ST has a ratio of 9:1, so something must be different internally.
Really?
