If you're + sets aren't calculated to roughly what you entered for your program maxes then you're lifting too much. If you say to me I can lift 160 deadlift RM, but when you do 120 deadlift only produce enough reps to demonstrate a max of 140, then you have to stop and think. The program is very unforgiving when using weights that are above your actual level.
Upload your spreadsheet and I'll take a look.
. Im at work, but will try to grab my spreadsheet from home. Looks like it might be time to re-calculate things! With the 5kg in mind, 140kg x 6 would give me a 1RM of 167, which is 7 kg (isnt much) above the 160kg you just mentioned.
