Think I've finally got my refund, complained to the Google Play Store last night and got my refund within a few hours. Not showing up in my account yet but it shows up in Google Wallet so I'm confident.
Just had to break the 7K barrier...
[/QUOTE]
How did you achieve that?
Received automated email that refund will be made...doesn't say when ...
Ewww quadrant! It's a pointless Android 1.5/openGL ES 1.1 random number generator, why are people still using it?
What about real performance gains or battery life improvements, i.e. does Asphalt 7 run any better?![]()
Flashed the latest Trinity kernel. Overclocked to 1.7Ghz
Links are in one of my earlier posts from a couple of days ago.
Currently running at 1.5Ghz for daily use. Battery life should be a little bit better as I've under-volted it by 25Mv across the board.
TBH, it's such a fast device with games, I can't tell the difference.![]()
Does the Nexus 7 need to be unlocked and rooted to do this?
Absolutely.
You check Google Wallet?
Well I have now unlocked and rooted my device. Installed the TKT, but it doesn't allow me to change the CPU or anything else. The max freq for the CPU is 1300 and it's set to that and I cannot go any further. I have download the latest kernel, but I don't know how to use it or where it should be located for TKT to utilise it. Any ideas? Thanks
