- 2 Aug 2006
Hi
I'm undecided what GPU to get with
-Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
-Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
-Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel
I've been looking at a
-OcUK GeForce GTX 670 2048MB
that are £287 this week, is there any other card i should consider in this price range (this is tops i want to spend really)
I'll even consider a AMD card if its going to be better that the 670 for the same or less cash. I've no experience with model codes or specs for AMD cards as I've never owned one
Many Thanks
Many Thanks
