No problem
I think you will find that the voltage adjustment does work, you just need a DMM to see the change.
Cheers Dude, need to get me one of those bad boys
No problem
Can increasing the power limit damage the card?
No damage can come from raising the power limit, it's just a number used in driver level calculations to adjust voltage and frequency
Just ordered one of these. Was seriously considering a 7970 vapour X, but I do have a slight preference for Team Green, and the MSI was cheaper, so it'll be getting installed tomorrow![]()
running at stock, got a peak of 1241 core, but usually runs around 1150. not tried clocking it.
anyone found a way to quieten this card down before getting into os? and i know about the dust removal phase for ~30s.
making bios changes has the fan at about 100%
1189MHz on mine on the core during Haven. Happy with that, but the card is quite loud. I'm used to the Accelero Twin Turbo 2, and the 670 PE is like a high pitched hoover compared to that.
Still, small sacrifices and all that.
when i start my system up and go to bios the card is 100% reverse for 30s, there is a dip in volume but then resumes at 100%.
getting to windows is a similar time so doesn't normally bother me, was just wondering what actually quietens it down?
e.g. if went to linux would it run at 100% until X is started (when graphics driver starts) or would it eventually quieten down on its own?
Another decent boost (damn... both higher than mine).
"but the card is quite loud." ... really? what fan % is it running at under load? I suppose ambient room temp comes into this, one advantage of Scotland... is that it never gets warm up hereMines never gone temp wise over 60C (in games) and at that it's running at 43% and anything under 50% I can't hear over my pretty quiet Gentle typhoon case fans (but I am getting on a bit
). Though never obviously experienced the " Accelero Twin Turbo 2".
