Do you run your cards with waterblocks ?
Can't as none are made as yet,
considering swapping these for some that I can but concerned I won't get
good clockers
I have never used more that 2 cards because of the cases I use. I have thought about watercooling and using more cards but as you mentioned above not getting good clockers has put me off.
Tried 2 of your cards,but the 2Gb was a killer. Excellent fps just had to turn to many settings down/off.
+1
Thats why I limit myself to 1600p. I was running BF3 the other day with every setting maxed out and getting minimums well over 100FPS but if I switched to a multi monitor setup the performance would drop very badly.
Single cards are much better for ocing which really helps if you have a multi monitor setup.
Called at the shop I got my cards from today and I now have the option to swap out for a nominal fee.
Really fancy the cards underwater but its that nagging doubt of
how good the new cards would be,
plus a possible new psu for OC headroom?
PS sorry Gregster for sidetracking
How do you rate the 3d performance with the nvidia 3d vision?
Also do you think I would have more fun gaming in 3d or with 3 monitors as I can't afford to do both?
No real way to answer this. Try to see both in action before deciding. I would say Surround over 3D if I had to pick one.
I live in the middle of no where and the only people I know have xbox's so there is no way I can really test them out.
I got the choice of buying 2 more 37" LEDs and runnings surround or buying my self a decent 3d tv and the vision kit.
I have had a mixed experience with 3d in the cinema some movies I like some I don't.
Beautiful m8 makes me want to add 2 more now.
What's grade b items? From overclockers?
I have a flimsy sli bridge if u would like it, and it helps.
One word AWESOME!!!!!
Sorry to ask again, I'm being stupid b grade section on the overclockers website store?
Don't get me wrong the cards i've got are good, just wish blocks were out as temps rise quickly causing throttling preventing better performance.(IMO)
The other issue i've got is wether or not my psu(AX1200)
is upto to the task of 3 Classifieds as when using EVBOT the cards can draw
towards 375w from what i've read.
Why don't you change the cooler on your evga instead of changing gpu-while taking a gamble on a not so good as you have clocker?
The AC's are quite popular with the 6 series and cheaper/less hassle than what you'd lose selling your gpu.
No no no.
We will get him to WC the whole system next!![]()
The wife will love it!
Temps are good now I have the cards swapped over. Been hot the last couple of days and after putting quite an aggressive fan profile, it sits nicely around 55c and 50c. I will be purchasing a side fan for my case.
Blowing in or out? I would assume in to blow on the GPU's?
