- 28 Apr 2011
- North West
£130 not too bad since they're going for 200+ odd still, was assuming you paid that =/
It compared to stock speeds of the intel cpu's.
Would still get demolished when overclocked it seems.
Does full water cooling make any difference with Ivy? I'm running the same temps as above on 1.280vcore 65-70c Antec 620.
What volts are people having to use for a multiplier of 45? so far i've tried bumping ofset up from .40v to .80v without success. (.40v is stable at x44)
Who cares!!! every CPU is different. Week 18 will do 5.0 ghz at 1.25v ish on water normally it takes 1.44v. Dont worry what others are using. Different silicon different volts needed every time.
