Ok, you have to be doing this on purpose now?
I'll try and explain my thought process for you in the hope that you stop going round in circles:
Arknor posted a single isolated stat that he used to argue that Schumacher was out performing Nico.
I commented that you cannot compare 2 drivers using just a single isolated stat (I never claimed this stat was invalid, cherry picked, made up, or falsified in any way, merely that is was a single stat).
I then went on to add that the reason why you cannot use a single isolated stat is because it is possible to cherry pick a stat to say anything (again, not claiming Arknor's specific stat was cherry picked, merely that is was possible to pick others).
Then, by way of demonstration of that point, I created my own stat that was cherry picked that could be used to argue that Nico had out performed Schumacher.
Wether one stat was cherry picked and the other not, and wether one point is more acurate than another is completely irrelevant, my point was that you cannot compare 2 drivers performanced against each other on a single stat alone. There was no implication as to the validity of the original fact.
Clear?
Clear?
An expert on every thing and will argue forever. I admire his stamina.
X
