Ah that is quicker but still 39mins!
Thanks though![]()
Many thanks downloading now, I'm coming from Revolution 9.0 which has been jerky as hell for me, I won't need to wipe I take it?
Thanks
Thanks though![]()
It's never wise to cross roms without full wipe but if it works without it then cool.
Wanamlite is very good. Can't fault it at all
Try it![]()
Can I use any wipe tool or is there a specific?
CM10 isn't completely stable, unless you consider restarting your phone very few hours normal![]()
I just use wipe data option in cwm mate
1. Wipe data
2. Wipe cache
3. Wise Dalvik cache
4. Flash rom
All from cwm recovery
For the record, I ran CM10 for over a week or two without any restarts...
Hi Guys. Anyone know the cheapest place to get these sim free in the UK?
I too would like to know the best deal on one
I have a feeling it may be a good idea to wait for the nexus though? However -does anyone know if the storage // battery will be fixed in them?
Didn't matter anyway, seems like the latest build of CM10 has fixed the memory leak.
Chances are they'll not have any microSD storage, no Nexus device has. Although I'd be happy for them to break the trend, but I think Google will make sure that they ensure that anyone using the Nexus name will obey their rules.
What's the battery issue though?
