- 27 Dec 2005
- Bristol
Long rides are far more challenging and impressive. I'd love to do LEJOG at some point.
Do any of you guys use turbo trainers? im looking to pick one up this month ready for winter.
Tonight is the night we make our first attempt at doing a 20mph 30 mile ride. Am looking forward to it, will be the first proper ride since the c2c, so I *should* be the fittest I've ever been. I think.
I've rubbed down and sprayed quite a few bikes, but I've only taken one back to bare metal and it was a horrible horrible job. Very long, fiddly and messy job and I'd get it blasted in future. I've just had the wheels on my car powdercoated white and the finish is amazing. Powdercoating really has come a long way so I'd recommend it for a bike frame. Example wheel:As another Steely user has piped up I was wonder if anyones ever had their standby (or main!) steely blasted/resprayed?
if so are you pleased with the results? did you go to someone who just did bikes or anyone who does that kinda stuff?
thinking about having mine re-done after winter for a singlespeed project (may not be a good idea in hilly cornwall!)
That does sound pretty painful. I don't envy you one bitI don't like pain. My poor girlfriend![]()
Yes. I use this one.
That does sound pretty painful. I don't envy you one bit![]()
If you're riding on rougher roads you're actually going to have more rolling resistance at higher tyre pressures due to the vibration
yeah I figured powder coat was the way forward
anyone paid to have it done (blasted/painted) and got a ballpark figure?
[DOD]Asprilla;22791500 said:90psi on 24mm tyres on 23mm rims. Vibration? What's that?
Wikipedia said:Vibration is a mechanical phenomenon whereby oscillations occur about an equilibrium point. The oscillations may be periodic such as the motion of a pendulum or random such as the movement of a tire on a gravel road.
Vibration is occasionally "desirable". For example the motion of a tuning fork, the reed in a woodwind instrument or harmonica, or the cone of a loudspeaker is desirable vibration, necessary for the correct functioning of the various devices.
More often, vibration is undesirable, wasting energy and creating unwanted sound – noise. For example, the vibrational motions of engines, electric motors, or any mechanical device in operation are typically unwanted. Such vibrations can be caused by imbalances in the rotating parts, uneven friction, the meshing of gear teeth, etc. Careful designs usually minimize unwanted vibrations.
